Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
Thanks everyone for the replies. I ended up taking the bracket right off. My question now is during installation of the bracket/jackshaft you have a little wiggle room in the bolt holes so in theory could the jackshaft alignment be a little off now from where it was due to bracket being slightly in a different position? Putting pressure on chaincase side bearing? I did take pictures before disassembly but thats not really helping much. Thanks
Fords4life
- Dec 7, 2021
- South Dakota
The jackshaft bearings are of a self aligning type, not the typical roller or taper bearing type.Thanks everyone for the replies. I ended up taking the bracket right off. My question now is during installation of the bracket/jackshaft you have a little wiggle room in the bolt holes so in theory could the jackshaft alignment be a little off now from where it was due to bracket being slightly in a different position? Putting pressure on chaincase side bearing? I did take pictures before disassembly but thats not really helping much. Thanks
Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
They are just regular deep groove ball bearings. Wouldn’t a self aligning bearing be more like a wobble bearing?The jackshaft bearings are of a self aligning type, not the typical roller or taper bearing type.
Pstn head
The shaft should line up and the bolt holes in the bracket should also line up to there mounting holes to the chassis. As long as the bearing is fully pressed onto the shaft ther also shouldn't be a large gap between the brace and the chassis. Basically should go back together fairly easily.
Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
They all line up. I just noticed the jackshaft/bracket has a bit of movement, adjustment, play, whatever you want to call it, with the holes being slightly bigger than the bolts (Like most fasteners). Maybe a millimetre or two. I was wondering if the bracke/jackshaft not being in the exact spot it was before might be of concern. Almost need dowel pins so bracket would always go back exactly where it was before.The shaft should line up and the bolt holes in the bracket should also line up to there mounting holes to the chassis. As long as the bearing is fully pressed onto the shaft ther also shouldn't be a large gap between the brace and the chassis. Basically should go back together fairly easily.
Pstn head
I never really thought of that the holes are a little bigger and the brace not lighning up perfectly. It was my first time removing and reinstalling the brace, I hope everything lined up and the secondary clutch is running true.They all line up. I just noticed the jackshaft/bracket has a bit of movement, adjustment, play, whatever you want to call it, with the holes being slightly bigger than the bolts (Like most fasteners). Maybe a millimetre or two. I was wondering if the bracke/jackshaft not being in the exact spot it was before might be of concern. Almost need dowel pins so bracket would always go back exactly where it was before.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Maybe a centre to centre measurement from primary clutch to jackshaft would be in order before disassembled. 1mm adjustment/ wiggle room would translate at the end of the shaft
Just thinking out load
Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
I guess I guy could put a dial indicator on it and check runout.
Turboflash
- Mar 18, 2019
- Southern MN
Be careful what you wish for ... "someone" assembled that shaft, bearing, chain case, brace, etc at the factory. I would not assume it was done exactly correctly OR perfectly. There might be slight changes that would improve efficiency, alignment, etc. Many of us have seen the factory's work - some of it leaves allot to be desired. I have even watched line assembly at Cat in Thief River Falls. After that visit, every time I get a new sled, once I get it home, I basically disassemble it and re-assemble it myself. Sometimes, I just shake my head at the stuff I've seen.I never really thought of that the holes are a little bigger and the brace not lighning up perfectly. It was my first time removing and reinstalling the brace, I hope everything lined up and the secondary clutch is running true.
