I ran across this Horse Poser calculator and thought you might all find it interesting.
http://www.mtv411.com/auto/Stroke-Bore- ... #BasAltCal
Current Elevation is the elevation at which you know the HP. So that is 0.
Current HP is known HP at that elevation. So 140 to 145 should work.
New elevation is the elevation you want to know the HP at. For me it is 5000-8000.
Pretty interesting how much you lose.
Here is another formula that is interesting. It calculates the loss of compression at see level. I have it in a spreadsheet. If anyone would like it I can email it.
Altitude plays an important role in determining compression ratios. If the altitude in the area where the vehicle is driven is significantly higher than sea level, then the compression ratios will vary. To determine the effects of the altitude on a calculated compression ratio, us the following formula: Corrected Compression Ratio = CR - (altitude / 1000) x 0.2
using this formula the RX-1's compression ratio goes from 11.8 at sea level to 10.8 at 5000 ft and 10.2 at 8000.
So are we all shaving our heads now?
