What could possibly cause a strong smell of melting plastic on 07 Apex GT when running sled in garage to allign and set track tension ?
SharkAttak
hyfax
SERPAGS
Your sliders are heating up.
blue er
yup sliders make sure you have all your track clips as well
SharkAttak
check you track tension, do you have the stock track? if so, you might want to check into the slp wear pads and the 135mm wheels
The the sled is motionless not moving just at idle and you can smell a plastic odor.SharkAttak said:check you track tension, do you have the stock track? if so, you might want to check into the slp wear pads and the 135mm wheels
BigMac
- Jun 27, 2004
- Brainerd Lakes area, Minnesota
APEX GT 4 STROKER said:[The the sled is motionless not moving just at idle and you can smell a plastic odor.
You mean you're not spinning the track at all?
That's correct just idling.
SharkAttak
APEX GT 4 STROKER said:The the sled is motionless not moving just at idle and you can smell a plastic odor.SharkAttak said:check you track tension, do you have the stock track? if so, you might want to check into the slp wear pads and the 135mm wheels
really?, that's weird, i'd be checking all the electrical quickly
NY AttakGT
Maybe something plastic fell on the exhaust or exhaust manifold and is melting? Only thing that would be able to melt anything when machine is running but not moving is the exaust?.....unless a wire is shorting out to ground and melting the insulation.... Just a thought...
--Steve (O.C.)
--Steve (O.C.)
SharkAttak
did you find out what happened?
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
Is the sled brand new?? If so, it wil go away after a few miles. If not, you may have a tail light wire or something too close to the header.
SharkAttak
nate007 said:Is the sled brand new?? If so, it wil go away after a few miles. If not, you may have a tail light wire or something too close to the header.
07 GT APEX
Yamahammer485
He means how many miles is there on it. A new machine has a really strong smell for a while and can smell like burning plastic.
If your 07 has barely ever been riden, especially less than 500 miles, then thats probably why it smells.
ReX
I've seen this before when melted hyfax gets thrown up on the bottom of the muffler. Once that happens there will be a smell of melted plasted for ages (even if you clean it off well).
