Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
2017 LTX SE 3800miles (stock power) Started sled and was warming it up. Generally sled idles up during this process, maybe 1800rpm+/-. Not Today, stuck around 1200rpms....about 4/5miles she was going into limp mode at 212°.
Nursed her back to cabin no visual signs of leak. Either on the ground or somewhere in sled.
Thoughts on where to start looking??
Precursor to today....
Yesterday did 8 pulls on a lake (part of the Cisco chain in northern Wis) raced
XTX 1.75" track with tuner & muffler
SRX (completely stock)
Two Polaris850's and a 900t....
RAMSOMAIR
Sounds like thermostat may be stuck closed.
Doc Harley
- Oct 17, 2016
- Here & there
I'll take it out and boil it in water to verify?!?!Sounds like thermostat may be stuck closed.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
if it's out, replace it.
also maybe inspect water pump impeller.
Doc Harley
- Oct 17, 2016
- Here & there
Yeah, may as well. On both.if it's out, replace it.
Doc Harley
- Oct 17, 2016
- Here & there
Is there somewhere to drain the complete coolant system?
I second the water pump issue.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
The coolant hose on the exhaust side in through the oil change plate.. Take that hose off and she will drain..Is there somewhere to drain the complete coolant system?
I would change plugs if you find nothing wrong within coolant system.. The low idle almost sounds like you were running on 2 cylinders instead of 3?
Doc Harley
- Oct 17, 2016
- Here & there
I agree....Just thought it was odd. For a moment a thought a may have fractured the head gasket in one cylinder. Still running very well. I'll follow your advice in regards to drain. And pull plugs to see what's what.The coolant hose on the exhaust side in through the oil change plate.. Take that hose off and she will drain..
Since it's the end of the season I'll replace the thermostat and pull the water pump for inspection
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I have no affiliation to Maxima but this is quality coolant.. No mixing just straight in from bottle. Good for -34 . 50/50 Mix.I agree....Just thought it was odd. For a moment a thought a may have fractured the head gasket in one cylinder. Still running very well. I'll follow your advice in regards to drain. And pull plugs to see what's what.
Doc Harley
- Oct 17, 2016
- Here & there
Thanks, jonlafon...I'll look for it as I button things up.
Doc Harley
- Oct 17, 2016
- Here & there
Also....I have to get cylinder #3 to TDC in order to release water pump?!?!
Turboflash
- Mar 18, 2019
- Southern MN
Yes. Otherwise the balance shaft gear will prevent you from getting water pump out (water pump gear will be trapped by balancer gear).Also....I have to get cylinder #3 to TDC in order to release water pump?!?!
Doc Harley
- Oct 17, 2016
- Here & there
Ty.....idk. it's really taking along time to get up to 160° I'm 100% sure the water pump is doing its job. With 3800 miles on it, would you replace it as just a maintenance item? Idk......
Turboflash
- Mar 18, 2019
- Southern MN
No, if it's not heating up then IMO the water pump is probably fine but the thermostat is stuck open.Ty.....idk. it's really taking along time to get up to 160° I'm 100% sure the water pump is doing its job. With 3800 miles on it, would you replace it as just a maintenance item? Idk......
