stingray719
Seems the Viper throttle cable adjustment is a bit touchy. If you have had the flash done I would suggest checking your cable adjustment if you have any strange issues after the flash, as the flash does alter some TPS settings.
Attacker
Could this be related to the p0508 code I posted about earler
Genius
- Oct 8, 2014
- Goodrich IL.
- 2015 Viper XTXSE & LTXSE
My 2015 ran like trash, with some help from this site it now runs perfect, after a throttle cable adjustment!
snowriderjoe
Im guessing that's my issue. If i keep my thumb of the throttle when cruising to a stop it doesn't stall. This past weekend i did have it stall a couple of times when just "puttsing around". Any advice or instructions on doing the actual adjustment?
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Here is a copy of the 2015 dealer prep instructions for adjusting the throttle cable. Might be useful to someone.
Genius
- Oct 8, 2014
- Goodrich IL.
snowriderjoe
Thanks, I will check mine next time. Too bad we all have to deal with this. Seems lik it should be an instruction to the dealer when they do the reflash.Here is a copy of the 2015 dealer prep instructions for adjusting the throttle cable. Might be useful to someone.
stingray719
Both our 2014's after the flash were fine, but I always adjust any Yamaha I get right away. Even the 1981 Enticer in my sig had this issue so its not new.
