stingray719
Seems the Viper throttle cable adjustment is a bit touchy. If you have had the flash done I would suggest checking your cable adjustment if you have any strange issues after the flash, as the flash does alter some TPS settings.
Attacker
- Sep 11, 2005
- upstate NY
- 2014 viper ltx
Could this be related to the p0508 code I posted about earler
Genius
- Oct 8, 2014
- Goodrich IL.
- 2015 Viper XTXSE & LTXSE
My 2015 ran like trash, with some help from this site it now runs perfect, after a throttle cable adjustment!
snowriderjoe
- Feb 23, 2006
- Champlin, Mn
- 2014 Yamaha Viper L-TX
Im guessing that's my issue. If i keep my thumb of the throttle when cruising to a stop it doesn't stall. This past weekend i did have it stall a couple of times when just "puttsing around". Any advice or instructions on doing the actual adjustment?
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Here is a copy of the 2015 dealer prep instructions for adjusting the throttle cable. Might be useful to someone.
Genius
- Oct 8, 2014
- Goodrich IL.
snowriderjoe
- Feb 23, 2006
- Champlin, Mn
Thanks, I will check mine next time. Too bad we all have to deal with this. Seems lik it should be an instruction to the dealer when they do the reflash.Here is a copy of the 2015 dealer prep instructions for adjusting the throttle cable. Might be useful to someone.
stingray719
Both our 2014's after the flash were fine, but I always adjust any Yamaha I get right away. Even the 1981 Enticer in my sig had this issue so its not new.
