bjerrang
Got a mtx with a RSI bar. No matter how much i reroute my cable i get tors warning at full deflection.
Found the powermad 10" extension , but its a bit to long. Isnt there a yami cable from another model that is a abit longer ?
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
How much taller are the bars?
When I added my Lake Effects riser I was about to just adjust the cable to make it a bit longer.
bjerrang
There is no way to route the cable better. Only solution is lower handlebar or longer cable. Im on to something with another 4stroke cable , but i must modify the connection to the carbs.
Did you reroute it under the bars. Just did a 2” and I removed the cable completely from the rest of the harness. Went under the bars and seems fine. I actually think it was a 2.5” riser.
Rox anti-vibration one.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
There is an adjester in the cable where it come up the steering column; it’s under a rubber cover. I remember my cable having a lot of additional length in that adjester. My riser was 2.5”.
bjerrang
The adjuster is to adjust throttle play. But the rx1 mtn cable fits. Only needed to add 2.5cm to the wire connection to the carbsThere is an adjester in the cable where it come up the steering column; it’s under a rubber cover. I remember my cable having a lot of additional length in that adjester. My riser was 2.5”.
I have dont this many many times when I thought it would not work it did. The key is to make sure there is slack in the cable at the throttle body's when full turned or it will set off the TORS.
