BURMAD69
ANY ONE OUT THERE HAVING POOR THROTTLE RESPONSE FROM THEIR RX! ??? AND IF SO WHAT TO DO ABOUT IT, SEEMS TO BLUBBER AT CRUISE AROUND 40 RO 50 MPH, LOWER NEEDLES ONE NOTCH, HAVENT RUN IT YET BECAUSE OF LACK OF THE WHITE STUFF.Probably lean raise the needles one but you should check the fuel screw settings stock airbox should be two turns out also may need to sync. carbs.
snowsweat
For what its worth, I was very suprised by how sensitive my Rage is to the fuel screw settings. 3/4 of a turn (out) and it went from hesitant to very snappy. You have to disconnect the carbs from the boots but I think you can leave all the lines on and just tilt the carbs to access the screw.
BURMAD69
Thanks for input guys, Will try adjustments this weekend going to Conover this weekend to find snow.Similar threads
