linemech31
I nave an 09 xtx with the gytr shocks. Will the 39" front end from timbersled bolt up to my gytr's ? Found a rock today needless to say i need to replace some parts so its time to upgrade.
Yes those shocks will work with the Timbersled.
linemech31
Bought the barkbuster kit used its the 39" kit. It didnt come with tie rods so i called timbersled and ordered the shorter tie rods. While i was on the phone with timbersled they told me that i HAD to use mtx shocks not the xtx shocks. He said the narrow kit need a shock thats 17" center to center. And my xtx has 18 center to center using my stock shocks will damage the balljoints. A little advice from you guys would be helpful. I dont have any 17" shocks.
Nikolai
All Nytros either came with a 17.5" or 16.5"(some MTX's) shock. Your GYTR shocks will be fine.
linemech31
linemech31
To take it a step further. Buddy of mine has a front set of hygear shocks off his 04 mxz. they measure 18 1/4" long. Anybody ever put doo shocks on?
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
Put a set of Ohlin's on a Nytro. They were on a MXZ 1000. Had to make some bushings for the bottom mount and a sleeve for the bolt to take up the slack in the hole.
