Where to buy 4deg timing key for -06 Attak?
My sled is in another place at the moment so i will also ask... Is it hard to change (do i need to lift motor out or is there space to remove right side cover easily)?
ATTAKED
You can get timing keys through http://www.hauckperformance.com. As for installing them, I have never! Though I've heard it's pretty easy. Search TY for it, I read about it somewhere, not sure where.
I tryed search, but unfortunately this site "search" function.. not so good.
Or should i just move pick up coil?
Turk
Tech Advisor
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
are you still running 87 octane on a 2 degree?
Turk
Tech Advisor
2 degree is still safe for regular. Anything over that & you should run premium.
minks_698
- Dec 21, 2006
- Wisconsin Rapids
- 2016 Viper MTX 141
What is involved with installing the Hauck timing key???
Anyone wanna quickly explain
If the Hauck Key is 4 deg, should premium be used?
Performance differances?
Reimond said:I tryed search, but unfortunately this site "search" function.. not so good.
Use the + when doing a search "timing + key"
Seems to work a lot better
AIRWOLF
Guest
- Oct 1, 2004
- New York
Mikey
- Thunder Bay Ontario
- 03 RX-1
I made pick-up coil move yesterday. Max movement of this coil is 3,5deg if you grind it all the way.
And yes, buy new gasget before opening the cover. I did not drain the oil tank. Just disconnected upper hoses and moved it on the side.
Charged RTX
That link is a little misleading. You can put as much timing to it as you want with the key. I have mine advanced 6 degrees with the key and it worked great. You also definately do not need to run super with just a 3-4 degree key.
