TIMING KEY
black700
camden,ny
i read in a post that adding a timing key can give you 4-7 horse power mid range and 3-4 on top. :Rockon: now doing this with the plugs you can get a pretty good horse power gain. it was said that the timing keys are'nt that bad to do.how much are these and where can you get them from. oh these hp numbers i read from one of allen's post so it's not bullshit number's. will these also work with allen's clutch no modifiying or anything
You will need a fuel controller.. and you will have to adjust the clutching to use the additional power..
a 2 degree timing key won,t change clutching or make u need a fuel controller. It will make your sled more sensitive to crappy fuel & you might want to run premium.
Is it proven that the timeing key does give extra hp on top, I would have thought it would give a boost in the mids but a loss on the top.
Also a 2 degree key would change that much, to need better fuel?
