gunnerthesnowman
Does anyone know what a stock apex timing map / curve is ???
FLYBYU
You have to have rapid bike to view it
gunnerthesnowman
FLYBYU said:You have to have rapid bike to view it
I thought when i had and ran the RB3 , all you got to see is what changes you were making ( + or - ) to the stock map / curve , but you did not get to see the stock curve !!
Turbor
- Apr 16, 2008
- mirabel,quebec,canada
- sidewinder
gunnerthesnowman said:FLYBYU said:You have to have rapid bike to view it
yep exactly youre right!
FLYBYU
if want to see the stock map look in the rapid bike section. This is the closest you'll see.
http://www.ty4stroke.com/viewtopic.php?t=71891
powderlites
- Sep 5, 2005
- Sicamous, BC Canada
- www.powderlites.com
Rapid Bike Timing
If you click on injection on the left it will show timing and how much it changes from stock
gunnerthesnowman
Re: Rapid Bike Timing
Thank powderlites , i will take a look at that on my buddys sled .
powderlites said:If you click on injection on the left it will show timing and how much it changes from stock
Turbor
- Apr 16, 2008
- sidewinder
still only shows how mutch it changes from stock....doesent answer his question: whats the stock timing map?
gunnerthesnowman
turbor said:still only shows how mutch it changes from stock....doesent answer his question: whats the stock timing map?
Yes , just took a look , only shows how much you are asking it to chang from stock , from what i see it does not show you what the stock was , unless i am not looking at what powderlites is , more info please .
Adrenaline Addiction
Do the RX1 and Apex have the same timing curve?
