timing retarding with more boost
yamaha_junky626
Claremont, MN
i,m running 7lbs right now and was thinking about going to 9.5-10 lbs. proline said he could change timing like 4 degrees and i should be able to run premium gas. would that be fairly safe, i also see synergy has a controller that can change timing with higher boost levels which would be the better way to go, fixed timing or adjustable. was also wondering if higher elevation would have much of an effect on how much octane you need.
