Skydog
Well i need a refresh! When pulling the cams and head . Timming marks on the fly wheel what mark do you line up? I know the two dots on the cams need to line up with the caps. What about the dots on the cam shaft spockets? Do the dots face each other? I forget, and pics??
Thank you Skydog
Thank you Skydog
Skydog said:Well i need a refresh! When pulling the cams and head . Timming marks on the fly wheel what mark do you line up? I know the two dots on the cams need to line up with the caps. What about the dots on the cam shaft spockets? Do the dots face each other? I forget, and pics??
Thank you Skydog
Cams are timed to the single line that would be closest to the 12 o'clock position as you are looking through the inspection hole. Sprocket dots point to the dots on the camshafts.
Skydog
Sprocket dots point to the dots on the camshafts?
So the dots on the sprockets should be pointing up?
Thank you
Thank you
SuperTurbo
- Mar 20, 2004
- Amherst, Ohio
- 17 LTXse Sidewinder
