Vmax4
- Apr 18, 2003
- Orondo, WA
- 2010 FXNytro MTX 162 SE with a 270 hp MCX Turbo and assorted goodies!
I have four 4-stroke snowmobiles in my fleet:
2003 RX-1
2007 Phazer FX
2007 Phazer Mtn Lite
2008 FXNytro MTX
Here is my question. I am planning on changing the oild and filter on the two mountain sleds because both got ridden around 2500 miles this winter, that is a no brainer. Now the RX-1 and the shot track Phazer only got ridden about 150 miles each, just enough to run some fuel through and make sure things didn't have a chance to sit in the same spot and rust/oxidize/corode.
Would you change the oil in the 150 miles sleds? With the cost of oil, I am thinking I might not. Didn't think I would even change the finter, but am having second thoughts. I am normally very particular when it comes to services. I do everything overboard.
What do you guys think?
2003 RX-1
2007 Phazer FX
2008 FXNytro MTX
grader
changing the oil after 150 miles is a waste of time and oil. its still new so dont worry about it.
tkuss
I agree I would not change it.
Cody
- Feb 28, 2008
Depends on how long they been sitting.
Cody
- Feb 28, 2008
Hey u should drop off the short track phazer for me on ur next revelstoke trip
i want do to some freestyle lol but my suspension abit to soft.
RX1Jim
I would not change the oil after only 150 miles. Would be just wasting oil.
rage man
could collect moisture over the summer tho thats why you shoud do your oil changes in the fall not spring
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Doubtful unless he starts the engine many times without letting it fully warm up. Summer is warm and dry with little to no condensation.rage man said:could collect moisture over the summer tho thats why you shoud do your oil changes in the fall not spring
Vmax4
- Apr 18, 2003
- Orondo, WA
Don't think I have ever heard anyone say you should change the oil at the end of the storage period. Thought the point was to get the acids and moisture caused through the cumbustion process out of the engine and away from being able to sit in the bearings and cause issues. That is the only reason I even considered changing the oil.
I plan on riding these two sleds just about 150 miles each year, just to keep things running. Or if we get a real low snow year, just as trail sleds. Not an issue this year. Anyone interested in a ride this weekend?????
-Steve
-Steve
Cody
- Feb 28, 2008
OH SNOW WHERE!?!?!?! SHOW ME THE SNOW!
SlowPoke
- Mar 11, 2007
- upstate NY
- www.synthetic-oil-tech.com
If you are concerned I would change it for peice of mind, especially if it is conventional oil or a blend. Full synthetic is a different story
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I would not change No point or benefit to such a short interval oil change.
Yamadoo
Yamadoo
ShootToThrill
Waste of time if oil is clean. Bout once a month I spin the clutch a little by hand so the same valve springs are not held open all summer.
- 14K
