sledfvr
My motor has less than 1000 miles on it from a 1025 kit build. All of the honing crosshatches are there from the last time and it looks like new. I had a cracked piston pin and caught it in time. I have a cheap 240grit hone. Its not a ball hone. I've heard nicasil needs a diamond hone or your wasting your time. Whats your opinion. Should I send it in or just put it back together. I'm putting in new pistons and rings in all four cylinders. Thanks
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
diamond hone for best results.
DaveyBoy
- Oct 13, 2004
- Fitchburg Mass
- lacroixmotorsports.tripod.com
a diamond hone is all i use on nikasil cylnders u should always give a light hone when reringing to deglaze etc the bore.oil usage becomes aproblem when u dont do this later on and rings really never seat the right way this is escpecially true w/chrome rings in certain bores etc
TWIN TURBO
- Aug 30, 2005
- Chicago IL.
- www.powerbygns.com
Should diamond hone when new rings are installed. I can do that for you, you can PM me if needed.
