hugger70mtnmax
So I was sidehilling across a pretty steep hill today and I hit a rock that was barely sticking out of the snow that I didn't see. Subframe is bent pretty badly. The spindle is also bent.
Here's my question for you guys. If I bend it straight and avoid hitting anything else really hard will I be able to wait till this summer to pull it out and reinforce it? I can see where the support plate on the bottom is bent.
Also does anyone have a spindle they would part with?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Yeah, you can get away with finishing out the year with it, but definitely keep a close eye on it (I guarantee you will) in case it starts to bend back.. Double check the A arm mount bolts, in case they may have loosened, as well as the spindle bolt too.
hugger70mtnmax
How does everyone like to straighten the subframe on these
Sounds like you bent yours bad, I bend mine every couple rides but its just one ski back from the other a few inches. I don't straighten in because I know I'm going to bend it again and I figure straightening it only weakens it by bending it one extra time.
It all depends how bad it is but I bend my 08 all the time and I keep running it.
I'm sure there are allot that disagree with me on this but I hit too much stuff to replace them. I love how much abuse the nytro front end will take.
09nytro
Ran my nytro all last year with it bent i just reset ski toe and off i went
