slednut
on the grass, when I got into the throttle it ratchetted pretty noticeably? Is this an issue with Yamaha now or in the past?
Slednut
Slednut
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Ratcheting is normal when new, mine stopped after about 50 miles on both my 03 RX-1 and 04 Warrior.
Grimm
I think ratcheting is more likely on grass because of the increase in traction in comparison to snow. However if it ratchets on the snow too much, you should tighten the track tension then.
MightyWarrior, I don't understand why the racheting would stop after 50 miles. Wouldn't it increase because of the new track stretching?
SledFreak
- Feb 7, 2005
- Ontario. Canada
Grimm said:MightyWarrior, I don't understand why the racheting would stop after 50 miles. Wouldn't it increase because of the new track stretching?
That's what I would think.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
I wondered the same thing but all I can say is it stopped. The finger track on the RX-1 was worse than the Ripsaw. I was concerned it wasn't ever gonna stop. That track did have 192 studs from the get go, so I'm sure the added traction didn't help matters any. Similar to slednut riding his sled on the grass.Grimm said:MightyWarrior, I don't understand why the racheting would stop after 50 miles. Wouldn't it increase because of the new track stretching?
slednut
This was a stock ER no studs, Yamaha demo. I'm a Yamaha virgin....so it concerned me a tad.. thanks guys.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Not a big deal tighten the track up a couple of turns.
hey guys, picked up my bro's attack" last week and ripped it across the lawn and it was ratcheting,picked the sled up and the track was waaaaaayyyy loose...so i would check your track tension
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I was told by my dealer once the proper track adjustment is made,and also after you stretch it out some and readjust it,no more problems,when i had the 03 w/pro action suspension it was worse,than what we now have. Typically yamaha has had some trouble under alot of load when hook up is very positive,just ask allen and some of the guys who have raced w/this new skid,and they will tell you its better than the older proaction,but still not the best out there,now we are talking about very hard hook up on grass/ice as snow does not provide this much pressure on the suspension and track,in snow it will all go away..
Manto
Ratcheting :?:
TopGunnSRX
The drivers are spinning inside the track, and jumping over the little knobby things on the inside of the trackManto said:Ratcheting :?:
Hope that made sense
MR.HAPPY
- Sep 30, 2003
- GREAT NORTH OF... ILLINOIS?
- YAMAHA
With the right adjustments it should never ratchet again!!!
Mine was loose too!
Just a couple turns & bingo!!!!!!!!!!
BR
Mine was loose too!
BR
slednut
Thanks Again fella's...now if my sled ever arrives!
welterracer
Track was too loose..
On snow im sure it wouldnt ratchet... you dont get the same amount of traction..
I had the same issue last year with my warrior, and tightened track and it never did it again
