yammiman
What kind of top speed are you guys seeing with S/C XTX's??
nytro boy
I,ve got a s/c shortie running 5-7psi with 24 upper gear and the best i have seen on the dreameter on a 1 1/2 mile pull was 128mph, although it gets there a lot quicker....
yammiman
So would you guess that to be in the 115 to 118 range on a GPS?
nytro boy
ya I believe the the speedo to be pretty good on the Nytro so i would say around 118-121mph, I passed my buddy on his Apex which he said was reading 127mph when I went by him and that was before I hit top speed....
yammiman
That's pretty impressive!!
07glide
- Aug 27, 2007
nytro
Hi there, i'm from winnipeg, looking at doing a nytro s/c, how do you like yours, any problems? What can you tell me about it? Thanks for any info.Greg
nytro boy said:ya I believe the the speedo to be pretty good on the Nytro so i would say around 118-121mph, I passed my buddy on his Apex which he said was reading 127mph when I went by him and that was before I hit top speed....
Daranello
Suspended
XTX speedo are only out 5mph, comopared to about 13mph on the Apex.
So 128mph speedo should be very close to 123mph gps
jimmyhighway
- Feb 6, 2006
- Northwestern Ontario
- 13 Skidoo Freeride 137
11 Yamaha Nypex MCX
Reading 130MPH speedo, I passed the gun at 126MPH. Speedos are very close on the Nytro.
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
Nytro xtx with stock gearing and no clutch machining will achieve full shift out at 116.5 on a stocker radar gun at NBSSR speed runs
thamax
110 mph is best i've seen on my nytro with powderlites setup
HURRICANE
- Oct 17, 2007
- Prescott Ont.
Check to see if your clutch is shifting all the way out.If so,that's all there is without gearing or machining your clutch
nytro boy
Re: nytro
install was pretty easy, everthing works great put setting up the GEMS box for our elevation was a couple of weekends of screwing around and another weekend to get the clutching bang on. I have now been riding it for four weeks problem free, once set up they seam pretty bullet proof at the lower boost anyways, i can't comment on higher boosted sleds....
07glide said:nytro boy said:ya I believe the the speedo to be pretty good on the Nytro so i would say around 118-121mph, I passed my buddy on his Apex which he said was reading 127mph when I went by him and that was before I hit top speed....
