just wondering guys if the tors malfunctions if it will shut the sled off and not just kill the idle? mine seems so actually shut the sled completely off when i let of the throttle sometimes. played w/ the throttle while driving it and it would shut it off and then turn back on.
It should only be limiting the rpms to about 3500rpms or just below the clutch engagement. You could try and bypass the system temporarily to see if that is the problem but it sounds like a different electrical gremlin.
