srx700lt
I will change my torsion springs to a heavier version, question is, what springs shall I get? I'm roughly 260 lb with gear and also would like to be able to carry extra gas. It bottoms out way to easy as it is now.
I've seen that there are some different springs available but I struggle to find any information about them.
Do anyone have any table showing the different types of springs and their characteristics?
Also, does anyone have any suggestion of what springs to get?
HABS 1
- Oct 22, 2015
- corunna,ontario
- 2006 apex gt,136 Hartman ext,dalton clutched,full excel exhaust,yamiheaters,cna pro ex white skis,hid lights,mtx riser,1.5 intense track,etc,etc!---2021 sidewinder xtx se
travis at bop sells a aftermarket aluminum torsion spring cam... it replaces the stock plastic one with 3 settings to one with a 4th stiffer setting, i put a set on my 146 but still have it a 3 and have never used the higher setting, im 265 in shorts and a T, i found changing the front skid spring to a stingray spring really helped everything for me for sag or squatt , i might have 1 inch sit in when i get on the sled set up like that!I will change my torsion springs to a heavier version, question is, what springs shall I get? I'm roughly 260 lb with gear and also would like to be able to carry extra gas. It bottoms out way to easy as it is now.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
I was going to order a heavier spring but never did
srx700lt
I swapped out the stock shocks for Ohlins, it's major improvement but shocks alone can't fix the issue of the sled bottoming out.
But thanks for the info, it is a step in the right direction to understand what's possible to choose from.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
I put the heavy springs in my 2017 ltx. I think there was only one choice. Full load I ran them on the second setting with out issue.
Heavy springs do make a difference
Pstn head
Along with the heavier springs you can also try, Yamaha has like a helper spring thing, sorry I don’t know what it’s called exactly but I believe it’s factory on the fully jammed Stx. And is also available as an accessory.
