MikeAllard
Dumb question but my Nytro came with the left and right tortion springs at different settings. Shouldn't these be the same? Also, I've read a lot about the Front Limiter strap needing adjusting, I did bring mine down one slot, but shouldn't all these references be to the Front Limiter Straps (plural) - there are two of them right?
arteeex
The owner's manual says both torsion springs should be at the same setting. And, yes most people are referencing the two straps in the front of the skid.
If you have a short track Nytro, I'd suggest going two holes shorter on the front straps.
rrxx-1
The springs should be positioned the same on both sides. There are two limiter straps, one front and one rear. They are independent of each other..............
NyTrOMaNIaC
I have heard of some people using different settings on their torsion springs to get their suspension dialed in to the way they like it. I haven't tried it myself being I'm looking for an absolutely no bottoming effect, but it isn't that hard to adjust on the trail and shouldn't hurt anything, might be worth a try.
