BryanD
- Jan 8, 2019
- Southern Michigan
- 2009 Nytro Xtx
First time messing with a snowmobile track here....
I just recently installed a few new bogeys on my 2009 Nytro xtx. I'm just wondering if I have to tighten/loosen the back idler wheels for the track to adjust or how it works? Also, how am I supposed to line it up exactly? Thanks!
markyb
- Feb 6, 2015
- Twillingate, NL
- 2009 Nytro XTX
- Twillingate, NL
Yes. Loosen the nut on the back shaft. Then use the adjustment bolts to adjust tension as needed.
Once you have aligned the track it’s a good idea to run the track a few turns to make sure it’s still inline.
Tighten up the back shaft and you’re good to go.
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
The manual gives you a pretty good guide on how to do it. After you adjust, start and spin track 4 or 5 times, shut down and measure distance of track to metal guides. Should be exactly the same both sides, if not, adjust and repeat. Once you get it set (I used a dumbbell in the track for correct weight deflection) you should be good for a while.
BryanD
- Jan 8, 2019
- Southern Michigan
- 2009 Nytro Xtx
thanks to the both of you for the good info. I as well used the dumbells and it all went smoothly and I’ll be on the trail tomorrow!
