attaker28
Hi all,
im looking for some tips or tricks on changing the track on an '06 attak. idk how but stock one ripped in half, 2750 miles. any help will be greatly appriciated. thanks
Len Todd
Well, ... you are going to have to open the chaincase and remove enough components in there to be able to move the PTO end of the driveshaft back and down far enough to slide the new track on. You will also have to remove the PTO side Bearing to do this. When you put the PTO side bearing back on the Drive Shaft, be sure to center it by fastening it in place and then tightening the set screws on the bearing collar. This is nearly the last thing you do. This will center the axial endplay of the Drive Shaft. A little anti-seize on the PTO side Bearing ID helps them come off easier next time.
