YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
I just sold my 2003 RX1, and bought a 2006 hamaha apex with a lot of upgrades, it has the longer track, GTYI front sbocks etc... it has 10,000 miles on it. Im looking for any tips, tricks that i should be aware of that i can get looked after before the snow falls
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
A lot to look at, but let's start with NUMERO UNO.
Bulkhead & Bushings.
Inspect for cracks where the A-arms attach to front end.
If the bushings are really sloppy, replace them, preferably with "Oilite" bushings.
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
Thanks for the tip... please forgive me.. as I'm new to this. But can I inspect this without taking it all apart? Is there a quick way to check the bushings any tips? ThanksA lot to look at, but let's start with NUMERO UNO.
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Yes
Roll onto your back & creep your head under the very front where the bottom A-arms attach.
Just look for cracks.
Unless you have a lift then you don't have to crawl around like a snake & get oil in your hair or metal chips stuck in your elbows.
If the A-arms are sloppy in there, it's like hitting that bulkhead with a hammer 8,000,000,000 times per weekend.............they can break.
If NO cracks, just kinda pick the front up & down a bit to see how sloppy it is. Watch where those bolts are.
YOU'LL KNOW! It will be noticeable if it's sloppy. If you don't notice it then it's probably OK.
I think there's some vids on some posts here somewhere.
Do a SEARCH for A-arm bushings
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I loved my 06 APEX GT, I would wash and detail dry you will learn a lot. If all is straight and no wiggle ( the sloppy movement Steve is talking about). I would have the shocks rebuilt by CannonDale on this site. Many have had exhaust issues and you again will know if BACKFIRES or obvious sound in middle of the sled. This is as good a trail sled as you can buy in my not so humble opinion, I put >10,000 miles on that sled and loved them all and always made it home. Only repairs were shocks and the exhaust I described. ENJOY
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
Thanks Boss!!! Love how descriptive you are.. love it!Yes
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
Thanks!!!!I loved my 06 APEX GT, I would wash and detail dry you will learn a lot. If all is straight and no wiggle ( the sloppy movement Steve is talking about). I would have the shocks rebuilt by CannonDale on this site. Many have had exhaust issues and you again will know if BACKFIRES or obvious sound in middle of the sled. This is as good a trail sled as you can buy in my not so humble opinion, I put >10,000 miles on that sled and loved them all and always made it home. Only repairs were shocks and the exhaust I described. ENJOY
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
I guess i should have first asked if you have any information from last owner as to what & when he did to sled.
At 10,000 miles, the bushings, donuts & shock rebuild should have already been done once maybe even twice.
We'll look at donuts when you're done with front bushing conclusion.
Change the relays to the latest versions, and if the starter solenoid hasn't been changed in a while, change it also. I would stay with the Yamaha starter solenoid.
Do you know if the previous owner had ever changed the drive axle? Many of these often broke with higher miles. Also inspect the left side drive bearings.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Upgrade the headlights to HID.
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
Which relay?Change the relays to the latest versions, and if the starter solenoid hasn't been changed in a while, change it also. I would stay with the Yamaha starter solenoid.
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
Its been done already..Upgrade the headlights to HID.
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
The axle bearing and speedo were just done last year.. not sure about the axle though.. what is a sign of the axle needing replacing?Do you know if the previous owner had ever changed the drive axle? Many of these often broke with higher miles. Also inspect the left side drive bearings.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I have an 06 Apex GT that now has about 8600 miles on it. It is still a 121". I have replaced the track with a Ripsaw 2 and upgraded the driveshaft to the thicker one from a 2012 Vector (also has extrovert drivers) but had to have a machine shop modify the chaincase end to fit in the chaincase because the older models don't have the extra support bearing. I have also had to replace a cracked bulkhead (was probably cracked before we bought it). I have installed Oilite front end bushings, cooper exhaust donuts, upgraded stainless steel y-pipes, the larger Excell X-wheels, 2" Lake Effect pivoting riser, and probably some more things that I am not remembering right now. I bought a 15 Viper LTX turbo a couple of seasons ago and the Apex is our spare sled now.
- 6K
