Gibby
- Jan 28, 2005
- Jackson, Michigan
- www.fitzgibbonstruck.com
i was wonder how much track clearance you need on the front tunnel protectors, i have a xtx and the dealer put a 1 1/2 crossover track on it, it does not rub but it only has 1/8" maybe a 1/16" between paddle and protector is this enough
Gibby
Gibby
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
That is how much clearance I have on my Attak with a 1.5X144 Crossover. I haven't had any issues other than the cooler protectors have a couple rub marks on them.
Gibby
- Jan 28, 2005
- Jackson, Michigan
that is the answer i was looking for
Gibby
Gibby
FLYBYU
it might rub when go to stop as the track ballons. I would of changed drivers size to have no worries. my 2 cents
Gibby
- Jan 28, 2005
- Jackson, Michigan
i will remove protectors first, i do not run studs so this would be the easiest fix, this is what i did on my warrior with no problems, what advantage is there to changing drivers size besides gaining more clearance
Deadman
don't the protectors just make extra ice build-up under there??? I'm assuming to rip mine out of my XTX also..
FLYBYU
track clearance, get anti-rachets, it's like changing gearing= You'll be able to run your track looser,less hyfax wear, no track slip and little better holeshot
Gibby
- Jan 28, 2005
- Jackson, Michigan
my warrior never really ratcheted but i did go thru hyfax pretty quick until i switch to the expert x then all hyfax wear was gone
LazyBastard
The bigger the drivers, the lower the approach angle. The lower the approach angle, the lower the friction and the better the performance. Running the track loose will NOT help slider wear and will NOT improve performance. Running the track loose will allow it to slide slightly easier IN YOUR GARAGE, but when you're moving, a tighter track will balloon less, which leads to pumping less air and improved performance.
- 6K
