tpayner19
Does anyone know what track clips are needed for a Camoplast Ice Ripper XT? I can't find anything online.
Thanks.
Todd Payne
Thanks.
Todd Payne
Vectornut
Google "Camoplast Ice Ripper XT track clips" and you should be able to contact a dealer who has these track clips.
RoyalBlue
Spendy
How will you attach the clips to the track , have had bad luck with the manual clip tool with socket end , matter of fact just chucked it in the garbage , we found the tool that worked the best was the Air Clamp or the Bolt Cutter Style but they are spendy.
I gave up on reclipping and bite the bullet and replace the track , loose clips could take out a heat exchanger , Ice Rippers are also big money "Good Luck"
SRXSRULE2
I agree. I have re-clipped tracks before. If you don't have the tool, you'll have to buy one. The first one pictured is expensive and it breaks. The threads strip. Took it back and got it replaced. Broke again. Fed up, we had someone replicate it for us made stronger. Now it wont fit the new style tracks because the new window styles are narrower. Money wasted when you can just buy a new track and be done with it.
My opinion, if you need a couple clips then re-clip it. If you need a dozen or more, replace the track. If you do re-clip, make sure you get them on tight or they will come off and cause carnage.
RoyalBlue
Stripped Out Junk
10-4 on the stripped threads , ours did the same.
MT.man
The vise type it its not the more exspensive type doesn't like air tools and states that on the label. Been there done that.
