Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
I put a Camso Ice Storm track on my Viper RTX 129" sled. I am finding that it howls a lot more than any unstudded or studded track I have ever had before at all speeds. In fact at 55-57 mph it is outright screaming. Anyone had this problem with one of the "Ice" -- prestudded tracks and if so, what if anything did you do to stop it?
Mills
- Dec 4, 2007
Has anyone ever thought they had track howling going on and later found it was a bad jackshaft, driveshaft or other bearing making the noise?
every sled i own has track howl at certain speeds.
Every all-Japan Yamaha I owned had track howl also.every sled i own has track howl at certain speeds.
However, the Cat chassis Winders I've owned are much quieter in the track area. I don't know if it's due to the inner track rubber bumps on these Cat-specific tracks or the more open tunnel area.
turbogts22
- Jan 16, 2021
- Spooner, Wisconsin
- Two 2010 Phazer GT's
I friend of mine installed a new track and hyfax on his Cat and it was really loud at all speeds. Turned out he didn't taper cut the rear of the hyfax and the track clips were catching on the squared off edge making all the racket. It cleared up on it's own eventually but it wasn't a pleasant ride. Most likely not the same sound you're experiencing.
Mills
- Dec 4, 2007
I have my hyfax taper cut but, it may be too far back. I have a new set that I am going to put on to see if that is the issue. I also ordered all new bearings for the entire chassis as it has 10k miles on it. I clean and repack the bearings each spring before storage and again at midseason but, Cat bearings have never been good to start with so maybe new bearings will do the trick. Every pure Yamaha sled I have ever had has steel ball carriers in each bearing. The Cat bearings have plastic ball carriers in their bearings so maybe they don't last as long even with maintenance
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
The storm tracks with their unique lug pattern seems to generate complaints of howling above and beyond that of a normal track with uniform lug height. It could be lug design, it could be the way the weight is distributed by the track (center heavy).
Fast
- Sep 25, 2018
Yup,had the dealer install the storm150 on my 2019 srx from brand new and it was howling like crazy. Brought it in for the 300 mile check up mentioned the howling they said it was the track then said the oil was silver from the chaincase but everything was ok. When I did the chaincase inspection at the end of the year the snap ring on the bottom gear was off and gear had worn 90% thru the chain case cover ,damm After fixing everything I noticed the howling was only around 40 to 60mph then dissapearedHas anyone ever thought they had track howling going on and later found it was a bad jackshaft, driveshaft or other bearing making the noise?
Mills
- Dec 4, 2007
Well I found the issue this spring when I tore the sled apart. Apparently dumb-#*$&@ me did not cut the clutch side hyfax off at all last fall when I put a new set in the sled and the track clips were catching it. I also went through chain case, jack shaft and all bearings to ensure none of them were causing the howling - all was in good shape. I put a new set of hyfax on that were factory cut and put everything back together and found all of the howling went away. I guess maybe I had too many Shiner Bach's BEFORE I got done putting the hyfax in it last fall
- 48K
