dremmick
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I think it will last. Not much different then stud pull through. Interested to hear others as I am no expert
DaveRX1
If that cut goes all the way thru the track it will not last, if it is just thru the rubber and hasnt cut the plys.......you will be ok
dremmick
xt_gt
if the plys are the fiberglass rods, they are just above the cut in the pic (finger)
i wonder if there is a way to put 2 rivets or something on either side of the cut with some sort of flexible plastic or whatever material to prevent the cut from getting worse.
i don't know just throwing random thoughts out there.
dansranger
from experience if you don't do anything to fix it, it will not last. I believe someone drilled a hole at the end of the cut to prevent more tearing. I did not hear if it worked or not.
dremmick
any other input guys I found a good deal on a cobra or should i hold out for a intense? if i dont use this track i just lost $200 dollars.
Daranello
Suspended
I'd run it, many guys cut down tracks to 14". What's the diff
dremmick
what should i do to prevent it from ripping more?
xrrider
There used to be a company that repaired track damage like that, but don't know if they are in business anymore.
- Jun 28, 2004
- Clinton, Wi.
Google Carrol Tech track repair. You'll find a few places that do this repair.
Nine2Nine
dremmick said:what should i do to prevent it from ripping more?
If you could get it clamped to a piece of plywood and cut a half moon with a hole saw you would stop the tear and the ripping effect.
couch
hole drilled at end should limit further tearing ... otherwise run it
Dimebag
Drill a hole and use a lighter to burn off loose fibers/threads that may occur.
Supa Dexta
Poke a soldering iron thru it, hole + burn at once.
