apexhank
- Mar 5, 2011
- HUDSON FALLS AND BIG MOOSE LAKE, NY
- 2021 SIDEWINDER LTX GT (soon)!
2019 SIDEWNDER LTX DX 6000 miles
2018 VIPER LTX DX 2200 miles
2014 VIPER LTX DX 8000 + miles
2014 BENNINGTON 22 ft. PONTOON BOAT/ 90 HP Yamaha
Does anyone know an easy way to get track and suspension lined up with bolt holes? I struggle with them every time . Just replaced exhaust donuts, exhaust flex pipes and bracket that holds the three pipe up, on an 06 Vector LTX. Want to finish up and put away for the summer.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
apexhank said:Does anyone know an easy way to get track and suspension lined up with bolt holes? I struggle with them every time . Just replaced exhaust donuts, exhaust flex pipes and bracket that holds the three pipe up, on an 06 Vector LTX. Want to finish up and put away for the summer.
There is no easy way as far as I know?
It seems some have trouble and others don't.
I have done mine twice now, the first time was a pita and second time was much easier?
Just make sure things are lined up square/straight, put fronts in frst, disconnect transfer rod and hope the back lines up easy.
venture2
I have a 120" track so not sure if they are the same but I put the front bolts in first; then hook a ratcheting tie down strap around the suspension and tighten it so that it compresses the coil spring that's around the suspension shock. It only takes a little bit and I can pull the rear cross shaft forward right into position to start the rear bolts by hand.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Disconnect the weight transfer rod and the limiter strap. Should line up fairly easily then. It does help to have a second person on the other side to help jiggle or push on things until the holes line up. Much easier to hook the transfer rod and limiter strap back up than to fight with that monospring.
shed
i used to fight with it on all my sleds
always slack off the rear axel ....lots...
like 10 turns on the bolts
the front ones go in, first of course
flip the springs over so there is no tension
it makes the 2 rear bolts holes way easier to line up
