Northern Viking
- Mar 11, 2021
- Sweden
- Sweden
- Multipurpose 2009
Hi.
I have a Venture Multi-purpose. The inside of my track is rubbing a bit on the top of my rear shock mount.
Anyone else had this problem on the 4stroke Venture? I've seen some posts about this issue on the Nytro, but nothing about it being a issue on the Venture.
Thanks in advance
Thanks in advance
RobX-1
- Coldwater, OH
I know @Srxspec (Ulmer Racing) offered a track rub kit for the Apex and Vector/Rage to address a similar issue. Not sure if his kit would be applicable to your Venture Light but might be worth checking.
Northern Viking
- Mar 11, 2021
- Sweden
- Sweden
- Multipurpose 2009
Yeah I saw that but no idea if it will fit my sled, it's not listed under Venture parts. From pictures I've seen it's the same issue, but can't find any information about it being an issue on the Venture MP.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
If you could take some measurements I can tell you if it will fit or not. How wide is the rear shock mount (outside of mount to outside of mount).
Northern Viking
- Mar 11, 2021
- Sweden
- Sweden
- Multipurpose 2009
Will do. I have left for work now, at least two weeks, but will measure it when I get back.
Not sure if it's worth it for me to order the kit, I live in Sweden. I would have ordered it already if I was in United States. But maybe I can buy some bearings, washers and a bolt over here and I'll try to make my own kit.
