jakeho
Can anyone provide info on how to check the tension on my track? It seems a little loose to me. Thanks
langow
I know this isn't really answering your question specifically, but as long as you're track is not ratcheting under load, you're going to be fine. Many people will just keep loosening until it ratchets, then tighten it up slightly form there and call it good. Being overly tight can cause premature wear on your hyfax.
