Sean80
- Oct 14, 2015
- 99 Vmax 700
My track has studs up the center and it's my first time running studs. I have noticed that there is a bumpy ride or a vibration of sorts while crossing a paved road at slow speeds. Otherwise everything is good. Is this due to the studs? I've had a quick look at the track alignment and everything seems good.
Yes studs will do that. Just make sure you have them tight enough that the head is just slightly below the rubber of track.
Dinner
Agreeing with Cannondale27, you're feeing the studs ride along on the asphalt/hard packed surface.
