I'm having a real problem getting my sled to hook-up. I have an Apex GT and here's my set-up;
-Stock track w/ 168 Woody's Golddiggers 1.325"
-Control arm set 1 notch from Max. on spanner wrench
-Front shocks set relatively soft
-Limiter strap not adjusted from factory (not sure which hole it's in)
-Stock clutch set in 3-3 (soon to be Ulmer Stage II)
Sometimes (very seldom) I can hook up good but most often I just spin at take off. Most of the time I can make up lost ground ground when I hit the nitrous but I've seen several Apex that hook-up right out of the hole. I'm look for any suggestions you guys might have. Thanks.
