Traction LTX 137
swamp hog
Huntsville, Muskoka
Canada
2014 Viper LTX SE
4600km - 2014
I can't get traction! Limiter strap is all the way out and all I do is spin. What has everyone else been doing?
Changed to a ice cobra 1.6, I will let you know how it works after the weekend.....
BTW, What did you change your valving to?
revolving sounds like a plan. Not really sure about this stuff can you fill me in more. both rear shocks? and what exactly do you have them revolved to?
The sled just doesn't hook up if you revalve it too soft then you will bottom out
I have valving covered and you dont have to worry about bottoming out either. $80 a shock. Keep going back to my stock revalved rear shock. Its better than the Axis I also have. Valving of mine and Carver. Took 3 tries to get it right but it AWESOME!
Plastic transfer blocks removed and shocks revalved, mine hooks up!
The ltx in our group is running with the blocks and shaft removed
