nytroERrider
Just went to dragraces and have some traction issues. I have the weight transfer nuts all the way down so its giving all the weight transfer to the back. When i was at the line and gun'd it the skis would come up off the ground only if i jumped on the back (weigh 210 suited up). Its seemed every time the skis went back to the ground it just lost traction. I have the springs on the hardest setting and the front floats set on 60psi. I dont know if its just me because i would think that I should be able to screw with the suspension some how to get traction. Any help would be greatly appriciated. Thanks Jake
Try to putting your rear springs on soft.Turn your clicker to 0 for drag racing and you should be able to launch really hard out of the hole.
nytroERrider
What do you mean by clicker? Is it on the front shock on the piggyback?
ridesrx
The clicker is the little brass slotted screw on the piggy back shock. Turn it all the way to soft, that is 20 clicks out from LIGHTLY seated. In other words, turn it clockwise in untill it lightly seats, then turn it 20 clicks to the left, or counter-clockwise. This will be full soft. The center shock, or front track shock has to be adjusted with the spring collar.
All the way counter clockwise is at 0
nytroERrider
alright thanks a bunch ill go try it after work
nytroERrider
this helped alittle but not as much as i would like. anything else? i cant try it out anymore because all of the snow melted and im bummed out!
BlkNytro
hows about studs??
nytroERrider
I am kinda low budget
BlkNytro
I see but with that wish list in your sig you better add studs in there.
