Trail tank
stook
saskatchewan
I was thinking about getting a trail tank, I own a 2013 xtx 1.75 and was wondering if the tank fits with the hoses that run to aux cooler in the tunnel? Looks like it will be tight.
It fits but watch the orientation. The first time I put mine on, the hoses actually got in the way preventing me from getting it installed.
And one more tip, once you have it installed look at the Spark Plug Coils, if they are hitting the tank twist them down or up to the 7 or 8 oclock position as this will give you the added clearance needed so they dont rub.
I just did mine a few weeks ago and it was easy. They provide a picture for spar plug orientation. If you haven't changed your plugs I would do them before installing the tank. Make sure the tank is as far forward so the studs/ nuts securing the tank are maxed out in the slot provided. Hope I'm making sense.
