swmichvector
- Jan 27, 2009
- Clare, Michigan
- 2011 NYTRO
anyone have detailed drawings for building a 102 x 10 trailer?? i have seen some online but you have to buy them and i am being cheap and wanting some for free. i will be building 1 very soon out of steel because i can get the steel for free and the axle too. i guess i can spend the $25 but the last time i did that for another project i really did not get what i wanted.
pat the rat
- Mar 13, 2006
hmmmm. i got one in my head but no print,i work in a large steel fabricating shop so if you have question,ask me
apltx08
Here this might be helpful...TRITON have a break down of all their trailers and accessories, it doesn't show any measurements but could be handy...
http://www.tritontrailers.com/assets/In ... 832008.pdf
or open this 2nd link and select "SNOWMOBILE" then pick and choose want you want.
http://www.tritontrailers.com/CustomerInstructions.aspx
open deck snowmobile trailer right?
do you want tip deck as well?
salt sheild?
i can almost draw the plan from memory with a couple of measurements for the axle.
heck we still use the one my dad made (not a tip deck mind you) in 1988. i had to widen it from 7' 6" to 8'6" but it still hauls sleds fine. just prefer my enclosed nowadays.
that is the only pic i have of it online. hooked up to my truck.
salt sheild?
swmichvector
- Jan 27, 2009
- Clare, Michigan
- 2011 NYTRO
i do as well. i am in the maintenance dept. fabricating is nothing new to me. thankspat the rat said:hmmmm. i got one in my head but no print,i work in a large steel fabricating shop so if you have question,ask me
swmichvector
- Jan 27, 2009
- Clare, Michigan
- 2011 NYTRO
thanks, that helps a lot.apltx08 said:Here this might be helpful...TRITON have a break down of all their trailers and accessories, it doesn't show any measurements but could be handy...
swmichvector
- Jan 27, 2009
- Clare, Michigan
- 2011 NYTRO
open, not too concerned with the salt shield yet. i work at a place that makes axles so i can get whatever i want. i do want it to tilt. that's the part i need to see or get a drawing for. i am thinking V front as well , my new sled has reverse but not my old 1.maim said:open deck snowmobile trailer right?
salt sheild?
