new rob
- Oct 18, 2009
- peterborough ontario
- Viper rtx
Need a little more ski pressure should I adjust transfer rod or tighten limiter strap one hole (2011 se) ???
Daranello
Suspended
I don't know. I'm in the same boat. Sled push bad
- Mar 1, 2004
new rob said:Need a little more ski pressure should I adjust transfer rod or tighten limiter strap one hole (2011 se) ???![]()
Transfer Rod First and see how it turns, doesn't take much turning too make it change. Try it and re adjust if Necessary go limiter strap last only if you need to...you shouldn't though
theCATman
- Feb 19, 2007
- WI
- Yamaha
X2 Transfer rod.
do you increase stroke of transfer rod or do you decrease it
theCATman
- Feb 19, 2007
- WI
- Yamaha
scubadoo said:do you increase stroke of transfer rod or do you decrease it
More transfer stroke = less ski pressure under throttle, but alot more under decell/braking.
Less transfer = more ski pressure all around.
rocky18
- Jan 28, 2012
- Rockford, IL
- 1997 Yamaha 600 Venture
2012 Yamaha RS Vector LTX (R.I.P)
2018 Yamaha SR Viper L-TX-DX
- Just below the Cheddar Curtain
so...how much change on the transfer rod at a time... 1/2 mark on the wrench? 1 mark on the wrench? More than 1 mark on the wrench? Thanks in advance
Rocky18, aka Mike
PS Almost summer here today! Ugh!
Rocky18, aka Mike
theCATman
- Feb 19, 2007
- WI
- Yamaha
rocky18 said:so...how much change on the transfer rod at a time... 1/2 mark on the wrench? 1 mark on the wrench? More than 1 mark on the wrench? Thanks in advance
Rocky18, aka Mike
Like I had PM'd ya about setup. Set the transfer rod to a 1 1/8" measurement.
This give about the best transfer for traction, and yet not too much so as to take away ski pressure either.
new rob
- Oct 18, 2009
- Viper rtx
Great guys I'll try transfer rod almost got it perfect but I've got a little push and inside ski lift . Daranello I've got tuner skis 6" inside 4" out limiter strap stock (top hole) transfer is at middle (std) wil make a little adjustment for more ski pressure 55 psi fronts 160 psi mega i weight 170 with gear maybe you can gauge from this for your set up.
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
new rob said:Great guys I'll try transfer rod almost got it perfect but I've got a little push and inside ski lift . Daranello I've got tuner skis 6" inside 4" out limiter strap stock (top hole) transfer is at middle (std) wil make a little adjustment for more ski pressure 55 psi fronts 160 psi mega i weight 170 with gear maybe you can gauge from this for your set up.
Rob,
Are you running studs in the track? That can give some push. Have you considered installing a 13mm sway bar? It will help with the ski lift and the EPS really reduces the additional bar feedback usually associated with the 13mm.
new rob
- Oct 18, 2009
- Viper rtx
Running 3-2-3-2 pattern about 128 studs. Would like to try 13 mm sway bar just not sure where they are available in my area .??
