Hammer Down
- Oct 7, 2016
- Loudon, NH
- Sidewinder STX-DX 2017
Apex XTX 2012
I have a friend who has a 2019 xtx and when gas is at about 1/4 of a tank or less, going down hill and applying the brake, the engine cuts out and stalls or pops really bad. It started doing this the middle of last year and again this year the last two rides. There are two other sidewinders in our group and they do not have this issue. Thoughts, suggestions, known fix ?
thanks!
thanks!
thanks!
Could be water in the gas or for some reason its too low and loosing fuel pressure.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Stock sled? Fuel pump is weak and or bad..
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I replaced my fuel pump and after 500 miles this year it has never done it once.. I run the TD fuel pump..
Hammer Down
- Oct 7, 2016
- Loudon, NH
Apex XTX 2012
Bone stockStock sled? Fuel pump is weak and or bad..
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
IMO some pumps are weak. I ran milder tunes for 10k. If your tuned at all the stock pumps is suspect at best IMO.Bone stock
- Sauk Prairie, WI
- www.ty4stroke.com
Di
did you reroute the return line with the TD pump or just bolt it in and go?IMO some pumps are weak. I ran milder tunes for 10k. If your tuned at all the stock pumps is suspect at best IMO.
Hammer Down
- Oct 7, 2016
- Loudon, NH
Apex XTX 2012
Two of us have run MAX spool 16sm no issues yet. The one with the issue is bone stockIMO some pumps are weak. I ran milder tunes for 10k. If your tuned at all the stock pumps is suspect at best IMO.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I did a reroute first. STILL DID IT. I have a link above to a thread I started last season about this.Di
Hammer Down
- Oct 7, 2016
- Loudon, NH
Apex XTX 2012
Okay here is the update. New fuel pump fixed it thanks ! J you called it
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Glad it fixed your issue. This site is about helping others and sharing knowledge.Okay here is the update. New fuel pump fixed it thanks ! J you called it
