dfapexride
- Oct 30, 2009
- Florence, WI / Mokena, IL
- 2012 Apex XTX
I know this is an Apex forum and I have two Apexs with snowtrackers...but I thought I would share my opinion since I'm experimenting wtih turner skis with 8" triple points (bergstroms). I just removed my stock skis on a Venture GT which had snowtrackers. I put on the tuner skis with bergstrom 8" triple points on the inside and basic wear bars on the outside. I was pleased with the lack of darting but I noticed now I think I need a little more ski pressure to reduce some pushing in the corners. With stock skis and snowtrackers pushing wasn't an issue. So far I have 200 miles on tuners with bergstroms and my vote goes for stock (non tuner skis) with snowtrackers. Tuners with bergstroms are good, but not as good as snowtrackers.
I've also seen snowtrackers are making a model for tuners skis too.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Crankster, before you spend even more money, you really should check your ski alignment. The skis should be toed out from zero to 1/4 inch.
