mtotguy
- Jan 20, 2011
- Montague, Michigan
- 2016 Rush 800, 2014 Viper RTX, 1983 Excel 3
I took the Tuner skis off my Nytro when I sold it and planned to put them on my wife's Viper. But the rubber bumpers are too think. I tried the bumpers from the Nytro, the ones from my Curves and the stock bumpers from the Viper. They are all too thick. I can't get the bolt thru the skis. Is anybody running the Tuners? What bumpers did you use?
mtotguy
- Jan 20, 2011
Or are the Tuners different on the Nytro than the Viper?
Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
The Tuners are different on the Viper and the Nytro. The Viper chassis is made by Arctic Cat, not Yamaha, so you have to find skis that fit Arctic Cat when you are looking for new skis on your Viper. I just took the tuners off my Viper and my grandson's Phazer, and the ski saddles are definitely different.
They make a really thin one for those skis... 8KN-F3743-00-00
mtotguy
- Jan 20, 2011
I'll check it out. Thanks.
walter
- Nov 22, 2014
- Linwood, MN
- 2015 Viper LTX LE Turbo
2009 Nytro XTX
2002 SRX 700
You CAN grind them down a little.. its a tricky process but my buddy did it on his sled. Just have to take a little off at a time and be careful. that was done with the stock saddles and it worked good all last season.
rednav
- Oct 16, 2015
- Aylmer, Ontario
- 2015 STX-DX
Even a 2016 tuner 3 won't fit a 2015/14 spindle. They are working on a fix as I was told by my dealer
Dreamsover2
Guest
- May 13, 2015
- NE Ohio
- 2015 Yamaha Viper LTX se
You can keep them tuners.
superb
- Apr 10, 2004
- Ottawa, Ontario
- 2015 Viper turbo, 2013 Apex, 2012 Vector LTX, 2010 Vector LTX
Put a set of semi aggressive snow trackers on your wife's stock skis, set the toe to zero and forget about the tuners. She will love it.
petey_sx700
- Nov 17, 2013
- Central, WI
- 2017 Sidewinder LTX DX
2017 Viper STX DX 146
2013 Vector
2018 SRX 120
- West Central Wisconsin
Chcck out the thread called Tuner Ski Installation. Gives illustrated way to attach Japan model Tuner Skis.
I ran a pair of Simmons Skis on my viper 2 yrs ago with Yamaha saddles. I used the rubbers from a Polaris Fusion I had laying around from working on a buddies sled. They are thin and only required a bit of edge trimming.
yamahatime
- Nov 4, 2012
- 2014 Yamaha SR Viper XTX with Skinz can, Skinz airframe running boards, Skinz skid plate, Skinz rear bumper, Skinz Arc A-arms with Fox EVOL shocks, Skinz storage bags.
Which Simmons? How were they on the Viper? I had them on my Apex and loved them. I had the GEN 3's.
I think they are gen II's. I have 3 prs that I used to run on all my rx's and apex's and loved them for years.
I rode an entire season with 4 -8" carbides on them but they are very heavy to steer on the XTX with the limiter straps brought down to keep the nose down. I think they would be fine on an LTX or RTX but the uncoupled skid of the XTX to get it to turn requires a lot more nose pressure, but they did eliminate my push on loose snow.
