dfroster
- Dec 18, 2003
- Kronenwetter, WI
- 2022 Arctic Cat Thundercat EPS
I'm tired of the ice build up. I've read removing the protectors can reduce ice build up. I dont have pics and don't plan on picking track. Any risk of track lugs hitting the muffler or pipes?
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
No it should be okay as long as you never plan on studding your track.
I've run without mine the last 3000 KMs with no problems - just less ice buildup.
Nytroman
- Dec 12, 2007
- Prince Albert, Sask
- 2008 FX Nytro
I removed mine two seasons ago and I run an 1.75" Back Country. Never had any issues with the track rubbing on anything. A word of warning though, if you remove the protectors on the heat exchanger be extremely careful. It is very easy to crack.
blew by you
whats the best way to remove the protectors on the heat exchanger?I was going to take a die grinder to the welds?GENTLY!
shockwave
- Feb 25, 2010
- St Paul d'abbotsford Québec
- 09 Phazer RTX
I want to run an 1.75" Back Country. do I have to remoove the tunel and heat exchanger protectors? If I don't will it rubs?
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Yes you have to remove both tunell and heat exchanger protectors.
I have the exact same sled, and same track. Both has to go..
Get a dremel and a some good cutting wheels and your'e ready to go
- And don't forget safety glasses.
Good luck.
Good luck.
stock
I left some of the weld on mine. Cut the tubing first then slowly grind it down so it has no sharp edge left. Dont get to close or green juice will be flowing.
shockwave
- Feb 25, 2010
- 09 Phazer RTX
stock said:I left some of the weld on mine. Cut the tubing first then slowly grind it down so it has no sharp edge left. Dont get to close or green juice will be flowing.
Thanks for the advice!
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX
2018 High Country 9000
2001 SRX 700
I left approximately 1/8" of each side of the tubings on the front heat exchanger on mine. I remove the material with a regular Makita grinder and everything was good. I can take a picture if you want.
thetruck454
I took the protectors off that where under the tunnel and left the ones on the front HX
- 6K
