Tunnel protectors on 04 Warrior!
Yamanator
Oxford,Mi
2017 Sidewinder LTX LE
Did the 04's come with tunnel protector's? I can't remember for sure but thought they did, and if they did do I have to change them when I stud it?
Thanks guys.
no tunnel protectors on the '04. if you stid it I would suggest some protectors and if you add a rear cooler you will definitely need protectors.
I was pretty sure my tunnel protectors were on from the factory.
#78 in the microfiche.
Thanks guys.
Yes they came with protectors.
No you do not have to change with studs.
You will have to extend them if you have or put on the rear cooler.
Yes, you guys are right! I was thinking of the tunnel extension protectors.
