Jonesynl
- Nov 6, 2014
- Roberts Arm, Newfoundland, Canada
- 2008 Apex MTX SE
Wondering how difficult it is to to remove the tunnel? Really would like to get it powder coated. How many hours work? What's involved ? Any links to a helpful thread?
apex55
It will be a ton of rivets!
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
Besides for that part of it, what's the major work involved ? The hardest part of it?
apex55
I've never removed the tunnel but had it stripped down to almost that. I would say removing the exhaust components then the heat exchangers then drills nh out all the rivets and brackets.
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
Okay thanks, I was hopping someone on here would be able to give me a answer because I'm pretty sure someone on this site, has removed a tunnel before
rayone02
- Dec 3, 2010
- adrian, mi
- 2012 Apex 2012 nytro xtx 2006 attak
I have to remove my tunnel also probably the hardest would be taking chaincase apart.
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
That's what I was thinking, but it's only an idea yet, might do it might not lol if you do, take some picturesI have to remove my tunnel also probably the hardest would be taking chaincase apart.
Way to much time to be worth powder coating it...IMO
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
I have lots of time on my hands, gives me a good project and something to do lol and your right tho
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
Yep, and if you are going to take it down that far, you may as well part-it-out while you're at it too. Better to buy an assembled frame, bust that down to PC it, then take the parts off your sled and put them back on the new frame - you're pretty much doing the same thing backwards...
Then CRINGE when the powder coat starts to wear-off.
