Turbo and nos??
Jensen
Finnmark - Norway
Hi, got a turbo warrior(mc-xpress). Was thinking about getting nos. Have any body got pictures of installing the nos? And where does the nos bottle go in the engine room..
Jensen :D
Jensen - There are a couple of places to mount a bottle. I have my bottle mounted where the airbox was on my 03 RX1, and I have the bottle mounted above the engine on my 05 with the stock airbox.
thats how you run it with the k&n's? dont they have an injector that goes in the filter? very interested, just trying to get info before i spend the cash. do you get any oil out of crankcase filter?
is the first pic with k&ns a dual stage? or is one fuel and one no2? any reply would be great.
THE FIRST PIC IS A WET SYSTEM, ONE IS FUEL ONE IS NOS, HERE IS HOW I INSTALLED IT ON MY TURBO SETUP.
TURBO TIME
WOW that is sweet!! What kind of HP you have??!!
Yamahajunkie - Sorry I didn't get back to you sooner.
The first pick is my own nitrous setup, and is injected into the carb boots, both fuel and nitrous. No oil consumption at all.
Second one is Holtzman's nitrous system, and the fuel is injected into the boots, and the nitrous is injected into the airbox. I just put these pics up so you had 2 versions of mounting the bottle.
thanks for the reply NOS-PRO!! is that 1st pic all NOS parts? did you get it as a kit? does it have a fuel pump. looking at all options (custom) and package (holtzman/ boss noss) thanks for your time. junkie
Hey Junkie - I mounted the nitrous kit from parts from Nitrous Oxide Systems in California, and yes, that is everything including a fuel pump.
2nd is Holtzman's, and the solonoids are hidden for a clean look.
If set up right yes both would! But i would say Nos alittle more. Lots less stuff to go wrong!
Skydog
turbo time.... what happens when you are underfull boost and you hit the n2o ..... i have a boondocker system and it does not allow for proper fuel delivery while under boost.... if you have done something different and it works, would like to know..... kip
