turbo clucthing
4strokin
Whitefish,Montana
I am going to be running a boondocker gt 25 front mount turbo on a apex mtn. with a 162 2 1/2 track just wondering where to start with clutching
I was running a bender stage II turbo on my apex last year.
I still have my low/high boost ramps!
But this is good only if you run a 4 ramp microbelmont clutch.
If not, I would suggest you get some supertips or heavy hitters adjustable ramps first.
I use HH's on my stage 2 bender. I have an 04 RX-1 with the mav track so it should be somewhat close to what you need. My HH's are 48 gms empty. I loaded them as such:
heal - empty
mid - large bolt w/1 thick and 2 thin washers
tip - large bolt w/3 or 4 thin washers.
This should get you started if you plan on running HH's.
J.
Jonny what gears and springs are you running. Thanks Paul
Stock gears.
Silver 2nd at 70 degrees.
stock primary
14.5mm rollers.
progressive Shockwave Helix so I don't know the exact angle but can adjust to meet my needs.
Thanks Jonny, appreciate it. Maxdlx
