greenthumb
Bought myself a turbo Phazer for the winter, and this being my first turbo sled I have a few questions.
-2007 mtx with the MCX kit and head shim installed.
-aftermarket tunnel with nytro skid and 162 track
-AEM brand AFR guage
-aftermarket fuel press. reg with guage
-typically ride in the 5000 - 9000ft elevation range
Previous owner had a connection at the local airport and was running a mix of av/pump gas. I talked to the tech at the local dealer who built the sled and he said any premium pump gas should be fine. I am currently using Chevron 94, but heard a rummor not to use Chevron brand fuel in a turbo. Any truth to this?
My AFR's are generally in the 12.0 - 13.0 range under steady throttle. This sound about right?
I am fimiliar with reconising detonation in a n/a engine. What would be the symtoms in a turbo engine be?
The sled doesn't like to start in very cold temps and needs several minutes of warm up or it will stall if you touch the throttle when it is cold. Once the warmed up it starts and runs great. Is this typical for this setup?
I am thinking of pulling the spark plugs to check them. Should I be using stock plugs and gap?
Otherwise is runs great and I am very happy with it. Is there anything else I should know to help the performance/longevety of the engine?
