Hey all ! Im just wondering if its posible to put the turbo kit from my rx1 onto my nytro? I dropped a valve in the rx1 so im thinking why not swap if i can. Has this been done? Can i get away with modifying the intercooler or is there room under the tight hood. Any and all info will be very appreciated. If this is at all possible i will take lots of pics of the project and share. Thanks
Probably cheaper and easier to just buy a turbo kit for the nytro and sell the rx1 kit for whatever you can get. Youre going from a 3 to a 4 cylinder. The only thing you would be able to use is the turbo itself, if its the correct size, and the oil lines.
What turbo is it? a rear mount or under the hood? the turbo itself is probably doable but all the piping and intercooler and connections to ecu from a carbed sled to an EFI not to mention 4 cylinder to 3 are all different.
