Got some info today from MCX.
They are going to start working on a kit asap.
Will come out with some numbers in about 3 month.
They are talking about 150 hp.
One of the guys working there is a moderator on one of the swedish forums.
His own words in our "yamaha 2007" thread.
Since the engine is 1/2 rx engine,the hp would be realistic,he said.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
If they could squeeze a reliable 150 ponies under a phazer mtn I would have one for sure.
low slung
- Feb 16, 2005
TIME TO set phazer to BOOST!!!!!!!!!!!!!!!!!!!!!
Auskins
This sled with a turbo and a 151" with a decent apporach angle would be sick!
Great to see the Phazer Forum up already Mr. Sled!
In one of the resent snowmobile-magazines over here there was an interview with Eric Marklund, the owner of MCXpress. In this interview he stated he wouldn't be making turbo-kits for any engine with less then 3-cylinders! He stated it would be too unstable under boost.
I guess he started thinking about it when he found out about the new Phazer... One should never say never!
slymax
Be OK for the bunny hills but won't touch an Apex or Vector on boost. IMO. I think it's an awesome sled BTW, Just can't see putting thousand of dollars into a turbo to end up with 130hp on pump gas.
Silver Streak
- Northern Idaho
- keystonemachineinc.com
I agree with Slymax. It would be a good woman's sled. That is with a decent track under it. My wife is on a MM700 putting out about 150 now. It is good for her. That is right about what the new phazer would be at the absolute most. Hers weighs about 490. So basically the phazer would be in the 700 class with a good track and turbo. If a person can even put a good track under it. I wonder who the idiot was that thought a mountain sled would be all right with a 14" wide track. But that is Yamaha's history. Make a mountain sled out of a flat lander sled. It doesn't really work.
SS
SS
RJH
Ryen said:Got some info today from MCX.
I believe....Unless the ECU on the Phazer is re-programmable – it’s going to be hard to add any modification. You can cheat the system – but a backdoor approach usually slows it down in some spots.
If these guys are saying they can do it – then they must have knowledge that the injectors can be changed – can they pass that information on?
I'll guess they know what they are doing!?
They have been puttin' turbos on bikes since the mid '80,so they must have figured it out.
RJH
No doubt at all - either...but this unit is injected - can we ask them if the ECU can be changed on the Phazer?Ryen said:I'll guess they know what they are doing!?
Jack_Shaft
RJH said:I believe....Unless the ECU on the Phazer is re-programmable – it’s going to be hard to add any modification. You can cheat the system – but a backdoor approach usually slows it down in some spots.
Can't see it even being an issue. There are plenty of aftermarket turbo/supercharger kits out there for the FI Apex, Phazer kits will follow in their footsteps.
-JS
HemiOrange
MPI remaps the computer for their apex s/c. According to Full Throttle Powersports, it is still too rich. It's accounting for some of the lousy mileage on the blown sleds. Sounds like MPI is working on a new map.
Superstroker1
- Nov 6, 2005
So you buy a base PhaZer for 5900.00 after discounts and install a 2 cylinder Turbo kit for 3200.
So you end up with a 150 HP Snowcross inspired sled that weighs 450 Lbs and has a power to weight ratio of 3.0 lbs/HP as compared to 3.9 lbs/hp for a Attack GT!!!!
Attack GT- 10,500.00 discounted
Phazer Turbo 150- 9100.00 complete!
Seems like a no brainer to me...
RX-Eskimo
- Jul 14, 2005
- Pond Inlet, Nunavut
- RX-1 2003 Mountain
That sounds like a doable project and would still have the better suspension for those big jumps...
RX-E
RX-E
Silverbullet
If you could build a operational turbo sled for $3200 everyone would be signing up....Plan on $5000 plus :ORC
